I just bought brakes for our endurance 75TS. Wilwood Superlite front and unlike my GTV which has Dynalite rears, I'll use Superlites in the rear too.
Does anybody have easier/cheaper/better ideas for rear disks than SZ ones?
I'm not allowed to move them outboards and SZ disks are bolt on and just require an adapter for the calipers. I would like something thicker to use the caliper better though.
- Maurizio
There was a option very close to the sz's, little rework needed, what I remember from a peugot 309 or somethingMicke wrote: Does anybody have easier/cheaper/better ideas for rear disks than SZ ones?
Ah, already found it (the brain still works
Edit: The peug 306 (dia 265.5 mm) looks like an upgrade from the 309....
- peugot306_front.jpg (43.34 KiB) Viewed 13078 times
- 75 backside
- 75_backside.jpg (41.22 KiB) Viewed 13083 times
- peugot 309 front
- peugot309_front.jpg (43.81 KiB) Viewed 13084 times
Banned.. ?
Daily donky.. ==> BMW 325d
E36M3 (3.0) Ringtool
==> definitely BANNED!
Are you using 4pot fronts and rearsMicke wrote:I just bought brakes for our endurance 75TS. Wilwood Superlite front and unlike my GTV which has Dynalite rears, I'll use Superlites in the rear too.
Any info on the superlites up front? We have some Superlite IIA calipers and I'm wondering if they can fit within 15" wheels.
Rice SAE
Searching using this forum is a %^@#$, is this the only non-ES30, cheap & easy rear brake upgrade to do?
I desperately need to adress my rear brakes but I'm having trouble justifying the ES30 Rotor price. Should have bought them years ago when they were cheaper!
- Maurizio
The SZ disc is difficult to find, the normal oe replacement stuff suppliers here on every street corner can't supply them.
Brembo SZ from performatek $172 without shipping
Brembo Peug ~E100,- or less if you really look for them
Maybe a simpler way, make an aluminum hat + wilwood discs at the backside. So you don't have to machine the discs every time you replace them.
(I prefer buying standard parts, without the hassle of getting the machined on time)
Banned.. ?
I'll ask around for the SZ stuff.
I also first planned on Wilwood disks but they don't have really suitable sizes. The small ones are too thin.
http://www.wilwood.com/Products/002-Rot ... /index.asp
If SZ fails I continue checking.
Sporttunergtv6
you can order the sz disks from any brembo distributor or dealer willing to make the call to brembo ita. i think you can get the pair for around $285 if you go that route.
otherwise there is a nice guy in the uk who sells 3g ultimate brake rotors. www.ricerocketuk.co.uk
the prices (icld vat) are on his ebay site as follows:
GR-10 RS-10 GR-20
SZ 3.0i V6 Coupé 89-96 F 3G-03922 £170 £182 £190
3.0i V6 Coupé 89-96 R 3G-04235 £170 £182 £190
i bought a set of 330mm discs from them... niiiice. do not forget to subtract vat if you live in the US
good luck
v
GR-10 RS-10 GR-20
good luck
v
What does those wilwood discs cost? Will they work with the performatek widening kit or do we ned something wider?
The wilwood discs is already down ~230g (in total) and then we need hats and mounting bolts/bobines as well. Probably worth it though.
Maybe there are some nice calipers that fits the std pos? (Fcuk the e-brake)
