UPS are well expensive! They even charged me an extra €17 euros this end, not including the €20 tax which was fair enough. The total bill was about 1.5 times the price of the product!
05 Corolla daily driver
My tank with the old fixings is now safely fitted, it just needed 2 extra-long screws and a pair of 3cm steel sleeves and fits perfectly. I am a satisfied customer. Well done Canton!
Installed the re-worked tank today. Looks fantastic in the car. Didn't realize how the old yellowed plastic one took away from the engine bay's appearance.
David, the fit up is almost spot on. If the angled tab's hole was moved 1/8" away from the tank both directions, the fit would be ideal. For mine, I opened up all 3 holes to 3/8".
To isolate the tank from the bodywork, I used o-rings either side of the mounting tabs. The large fitting at the bottom is a bit undersized, so I changed the Alfa hose clamp to a more standard jubilee-type clamp. This allowed the hose to be pinched tighter. The other barb-type fittings are unlikely to need clamps.
- From LHS.JPG (98.38 KiB) Viewed 20536 times
- From RHS.JPG (113.48 KiB) Viewed 20535 times
- Plan View.JPG (91.28 KiB) Viewed 20534 times
- ALFA GTV6 GP
Expansion tanks looks trick!
Does anyone know of aftermarket radiator coolant hoses I know Samco is a well know brand around the track any others ?
Thanks John
Thanks John
Alfa GTV6 3.0 (Silver)
Alfa GTV6 GP 3.0 (Red)
Alfa GTV6 GP (Concourse)
Sporttunergtv6
Sporttunergtv6
it's not possible to buy any thanks? still waiting for the response...Fiorano wrote:yes we cetainly are cracking not only to do the hieght fix- but to send off the catalog piece (if we make it in time) to IAS
so fear not, to RightPondians we may find an alternative to UPS shipping rates.
I will keep all informed.
BTW any one play with Mega Squirt?
