Gotech Pro Coil packs installation
Well I just received the Gotech Pro unit with Coil packs from JJ, now I need some help hooking the coilpacks. The V6 conversion on my Giulietta is nearing completion, in fact the car is getting painted right now and a new interior fitted, so I need some help with the coil packs as I understand JJ told me I should be carefull when hooking them up. Any help is greatly appreciated!
- junglejustice
Hey Federico, YES!
Aside from making sure that your connections are correct, the main thing to remember with VW VR6 coil-packs is never to unplug the plug-wires at the coil-pack while the car is running (like maybe trying to diagnose a dead plug/plug-wire/coil-pack...)
Also, never unplug the GoTech while the ignition key is on.
Then, whenever unplugging Gotech or plugging it back in, first disconnect power to the coil-packs!
Here is a picture for the correct hook-up...
- HPIM0998.JPG (38.39 KiB) Viewed 14220 times
- HPIM1002.JPG (56.5 KiB) Viewed 14221 times
- junglejustice
