Throttlebody size, ITB`s.
Building a "high output" V6. Have realised that the stock 36-37mm inntakes are far to small for massive power. Engine is fitted with most of the good stuff, forged high cr pistons, adjustable engine management, custom built exhaust ...... Can anyone with experience with ITB`s on the 3.0 12V recommend a reasonable ID for this engine. Power output should be in the area 260-280hp. In "four stroke performace tunung" Graham Bell writes:
Throttle bore dia: hp of one cylinder:
-36 27-37
-40 35-46
-45 43-56
-48 50-65
As I am working with motorcycles I choose to go for the GSXR 750 throttlebodies, ID 42MM. Anyone with Experience?
Jarle
-36 27-37
-40 35-46
-45 43-56
-48 50-65
Jarle
- Throttlebodies AR75 013.jpg (43.99 KiB) Viewed 9778 times
- Throttlebodies AR75 015.jpg (49.14 KiB) Viewed 9778 times
- junglejustice
Pretty interesting using the bike ITBs...
50mm up top tapering down to a 42-43mm seems to work fine on the big-bore 12 valvers that we have done... (You want the taper for velocity...)
Any way, use just one vacuum port per ITB with the MAP setup and then simply drill one tiny hole per t-body plate of equal size for idle! That way you don't have to mess with trying to always map idle or set the 6 ITB's to each remain open EXACTLY the same amount...
Pain in the arse if you ask me...!
Start with very small idle holes and then take them all progressively larger and larger to add more and more air for idle control! Set the ITB-plates to full shut - easiest!
i.e. Alpha-N instead of Speed-Density? A mix? Sounds strange.Jarle wrote:Throttle is mapped towards the TPS, and ignition towards the MAP.Open throttle for idle... I need vacuum for the MAP, fuel pressure regulator and brake booster.
