Mezevenf
Wiring to VR6 pack
Post by Mezevenf »
Hey all,
I have run into a problem,
We have 4 loose wires coming from the Gotech, but not sure in what order they are plugged into the VR6 coil pack. The wires are yellow, green, orange and purple. Anyone got a picture of how these are meant to be plugged in? Wiring diagram would be very helpful.
Would like to get this done ASAP, I wanna start it :D
Thanks in advance.
1985 GTV6 2.5L 12v V6 - Red
1999 166 3.0L 24v V6 - Red
NightSpec
I think JJ posted a wiring pic from a VR6 coilpack a while ago, it was in one of my threads
Mezevenf
Post by Mezevenf »
Found the pics but the wires are a different color.
Confused, wanna get the car started today!
NightSpec
Mezevenf
Post by Mezevenf »
S'cool, its running. Got it sorted.
NightSpec
cool mate! is it too hard to get it wired? I think I might put the engine in next month..
junglejustice
Post by junglejustice »
VR6 coil-pack hook-up...
4agedub
Post by 4agedub »
The Golf VR6 coil pack can be used in one of two ways...
1. It has got a built in ignition module as in the picture. Then you use 12v+ ; Signal 1; Signal 2; Signal 3 ; Earth. Gotech must be switched to external fire for this option.
2. You can remove the ignition module, switch the Gotech ecu to internal fire 12v+ ; Signal 1; Signal 2; Signal 3.
Gotech fuel injection systems
South Africa
Tel: +2711 3978197
Email: louis@gotech.co.za
