- Mezevenf
4500rpm cutout!
Hey guys,
Ran into a problem, when the tacho reaches 4500rpm it just drops right back down to nothing until it comes under 4500rpm again.
Any ideas whats causing this?
1985 GTV6 2.5L 12v V6 - Red
1999 166 3.0L 24v V6 - Red
NightSpec
NightSpec
Bernard,
Sounds like the engine is running fine, and that it is only a tach readout issue, right?
Do you have the GoTech Pro? I assume so. When Joe (from GoTech) was up in Seattle tuning the 3.7 he told us that the tach output of the GoTech Pro (on my 3.7), most likely would not drive the Milano tach, or drive it well. He said it would only take an inexpensive, readily available, "converter?" to put inbetween. However, we hooked it up straight and it seems to work on the 3.7. Anyway, a convoluted way of saying that you may need that "converter?". Either post on the GoTech forum or ask GoTech directly.
How is it running??????
- Mezevenf
Its running well, but the tappets are *very* loud.
Booked in next week for a tune just to get everything sorted.
NightSpec
NightSpec
- Mezevenf
- Need a cam belt cover.
- 24v1.JPG (102.69 KiB) Viewed 20689 times
- Large filter, I know.
- 24v.JPG (105.99 KiB) Viewed 20689 times
- Where the magic begins ;)
- alfaseat.JPG (59.28 KiB) Viewed 20689 times
NightSpec
NightSpec
- Mezevenf
The whole engine came from Glenwood Motors in SA, few things had to be modified to get everything sorted and fitting nicely.
NightSpec
NightSpec
- junglejustice
Sounds like one tappet isn't filled properly, let it idle until it's all warm (oil viscosity drops) and see if that solves it. Usually you get this when building a new engine, should be fine.
- Mezevenf
JJ - It's just the tacho that cuts out, engine still goes past 4500rpm but I cant tell how far
Dawie responded telling me I just needed some adaptor for the GoTech, can you supply said adaptor?
Thanks for the tip Mats, will see.
NightSpec
NightSpec
Bernard,
That sounds exactly like what Joe (from GoTech) described to us re. the 3.7. It should then be readily available, and it is probably much faster for you to pick up locally.
Hook up the GoTech ECU to a laptop and you can see the RPM there. Obviously you need to install the software on the laptop first.engine still goes past 4500rpm but I cant tell how far
