mark_atterbury
"special" V6 valve shims?
Post by mark_atterbury »
I was reading technical bulletins on the CD yesterday after finishing looking up information for the transaxle. I know, I'm boring. I came across two bulletins that stated very clearly DO NOT use 4 cyl valve shims in the V6 - they will fail.
Now I know what the little groove in some of the shims in my shim set mean, but...
I just set the valves about 5000 miles ago, and I am sure that I did not use only V6 shims. Does anyone have bad experience from using 4 cyl shims? Good experience?
If no one can make me feel better about this, I will have to go back in and dig out the shims. I'd rather not, but a dropped valve woudl be BAD.
Mark
Mark,Have been using same shims in both types for ages....No problems here.....
Cannibal
Post by Cannibal »
Agreed. Same ones used for years and years.
