KingDom
twin spark Alfetta GT
Post by KingDom »
Can the twin spark engine from the Alfa 75 fit with clearance under the hood of a Alfetta GT (4 cylinder hood)?
Dom
Post by la_strega_nera »
Yes. They fit under everything other than a GT Junior Zagato and 105 series spiders.
Ben,It fits the 105 junior as well...got a few running around here...
Barry wrote:Ben,It fits the 105 junior as well...got a few running around here...
Oh, i recalled someone on the alfa digest measuring it up and not having clearance on the 105 Zagato? Happy to be proven wrong... now would a 2.5 fit? :D
I dont know about the Z,but I reckon it should..Dont know though..
Yes,But an awfull bump in the bonnet is required..I remember pics of one in the old forum..someone in the states... :?:
And... I've seen then in Spiders as well.
Micke wrote:And... I've seen then in Spiders as well.
Yeah, but the spider i'd seen it done to needed a bonnet buldge to clear the cam cover/oil filler from memory?
iachella
Twin spark flywheel in Alfetta
Post by iachella »
Can the twin spark be dropped into the Alfetta with its own flywheel? In other words, are there any differences between the flywheel/driveshaft interface of an Alfetta (of late 70s era) and the twin spark? There was a sugestion to pull the flywheel off of the Alfetta and put it on the twinspark because of driveshaft issues. Is that true?
Stefano, Concord CA
74 GTV, 79 Alfetta GT
iachella [at] gmail [dot] com
All 4-cyl Alfetta based are the same as far as I know.
TS_turbo
Post by TS_turbo »
no real difference between nord and TS flywheels ... TS one is around 2.5-3kg lighter and its more dished ... i will make some pics and post later :)
Lighter? I have them both and haven't really seen any differance in weight, the TS one seems to have the weight further out though as the ring-gear is different.
Interface should be the same
:wink:
Giulietta24vTT
Post by Giulietta24vTT »
That is a sweet ride 8)
Chen S
ex Giulietta 24V Glenwood TT.
Sweet indeed but doesn't look like a TS to me (might be wrong though)
Mats, the early Alfettas had a 10 kg flywheel. My -78 anyway. The newer ones I have are 8 kg I recall.
Micke,????
