DaveB
Alfetta rear axle ratio
Post by DaveB »
Does anyone know where I can get a ring and pinion for an Alfetta with a higher ratio, approx. 4.55. I am prepping an alfetta for the track and the rules require use of the stock gearbox case and differential housing so I can't switch to a milano or GTV6 box. Any ideas would be appreciated. DaveB
From the Alfetta or Giulietta 1.6 you get the 41/9. The Giulietta 1.3 has 43/9.
DaveB
Post by DaveB »
Any ideas how to get an Alfetta 1.6 in the U.S. since we only got the 2 liter. Does the Giulietta 1.3 fit the Alfetta differential? (Do you mean the 105 series Giulietta or did they use that name on some of the transaxle cars also?)
I think you are looking for one of these type with a 1.3L donk.
116 Giullietta.jpg (132.91 KiB) Viewed 4582 times
