GTV6, ex Zender, turning into a racer
Re: GTV6, ex Zender, turning into a racer
Thanks Kevin. Give me a day or so, because I have moved abroad (Holland) and I need to look for my backup disk with all the photos. Will post photos of adapter I made. As far as A arms go, yes I did enlarge the opening since 160N springs require larger shock bodies, and 2,25" diameter springs
Thanks that a real help as my mate has these shocks and wanted to see how you did it .
- Maurizio
Kevin an extra tip:
To get some more stiffness in your bracket use a l-piece or a square tube as base material for the strip that is mounted onto the lower arm.
But when using a thin walled tube make sure that the you insert bushes at the mounting holes towards the lower arm. So that the interface point itself also is stiff enough.
- Square tube ring TS
- SIMG1193(cropped).jpg (42.24 KiB) Viewed 3639 times
- L-piece for daily ts
- IMG_0003(cropped).jpg (31.02 KiB) Viewed 3639 times
Banned.. ?
Daily donky.. ==> BMW 325d
E36M3 (3.0) Ringtool
==> definitely BANNED!
Summer is long gone, but here's a reminder of the good days!
[/url]
[/url]
[/url]
[/url]
[/url]
[/url]
[/url]
[/url]
[/url]
[/url]
[/url]
Beautiful pictures of a stunning car.
