Wipers
wipers go only slow speed. have not checked anything yet...any ideas
Yeah could be contacts in the stalk assembly on your steering column or shagged contacts inside the wiper motor. I would start at the steering stalk assembly first. They do go intermittent.
powderhoundcd
Post by powderhoundcd »
How many speeds do the wipers go?
Mine only go continuously slow or fast so I might be in the same boad as x-rad.
Three : Intermittent, slow,fast.
BTW: Fiats about the same vintage use the same wiper motors if you get stuck locating a replacement. Mine is using one out of a Fiat 128.
jrreeve
Post by jrreeve »
Should be three speeds...intermittent, slow, and fast. I used to have only 2 speeds until my fiancee broke the stalk on my unit and I replaced it. Now it has three.
Thanks for the replys!
I cleaned the contacts as best as possible. I have one speed, slow continuous.....
I have to check the motor terminals for power....
