Giulietta24vTT
My new Turbo Setup
Post by Giulietta24vTT »
Will have a go on this new buddy Turbo and see when the mighty powerplant starts to speen its wheel ,modified under-engine tubular manifold ,extra intercooler core and some water injection.
I reckon this setup will easily hit real 600 engine HP after tuning on 98Ron :roll:
Still looking for a special clutch for this Transaxle, any ideas?
Chen S
ex Giulietta 24V Glenwood TT.
Wow, more intercooling and water injection! You should have some really really low temps.
That's some motor, 24 valves, lots of displacement and lots of boost, I hope you find a way to hold all the power.
If you need any help with the water injection pm me.
AFAIK the only company having ready cluch disks for the Alfa is Helix.
Max torque capacity is 1428 Nm which should be enough.
http://www.helix-autosport.com/groupa.asp
If you go for this I have some spare flywheels to match.
Giulietta24vTT
Micke wrote:AFAIK the only company having ready cluch disks for the Alfa is Helix.
Thanks Greg ,thanks Micke!
Will need a good hard surfaced flywheel when the helix arrives.I'll let you know.
Chen S
Look out for the spline! The 'Group A' clutch plate has a different spline then the regular box.
:D :D :D
Clutches 1.jpg (143.01 KiB) Viewed 12673 times
Hey Mats!
You try to scare the shit out of me or what?
I had to check the clutch plates and lucky enough the splines on the Helix match the old TS unit I have.
Just making sure you stay on your toes... :wink:
The Group A clutch plate they advertize has a different spline to fit the Group A boxes...
Michael
Post by Michael »
Sorry about the off-topic question, but what alternator are you using?
I need to get something with a serpentine belt for my 164LS engine which is going into my GTV6. 164 alternator?
Cheers,
Michael
1981 GTV6
:D Michael..Mr Admin...I dont believe this...!!!
We have covered this everywhere....Shall I suggest you do a SEARCH?? :wink: :wink:
164 alt,mike...
164 alt,mike...
Michael
Post by Michael »
How dare you Sir :lol:
Actually, I could not find that thread - can you send me a link?
What kind of alternator is that ... can you make me a bracket :P
Michael
1981 GTV6
Giulietta24vTT
This time I'm using a cross over pipe under the engine through the rear sump area to clear a normal bonnet.
Haven't yet Plasma cut the 3 holes for the External wastegate ,two on the manifold and one for the DP ,this is what I magaged to pull so far.
The good news are that one can surprisingly use one of the 164 24v header on the right engine sude for the turbo , and the cross over pipe goes in between runners of cylinder 2 and 3, this side's manifold is mounted upside down....!
The left side's manifold I used is also a 164 one which I cut and reconstructed its branches to reach the cross over's area,a bit tricky but afters the cut off collector of that side is positioned it is a type lego job of completing the new lines.
Cheers ,
C.
18062006singlework 004.jpg (217.25 KiB) Viewed 12324 times
NewManifolds140606 002.jpg (211.96 KiB) Viewed 12322 times
18062006singlework 011.jpg (209.24 KiB) Viewed 12324 times
Chen S
bteoh
Post by bteoh »
Michael,
You can still use the alternator off the the 2.5 GTV6. Just change the pulley to a serpentine pulley. I think my mechanic used one of a nissan s13? However, just as easy to take off the pulley and run to your local autoelectrician to match up a serpentine pulley.
Cheers,
Brian
Chen,You scare me!!
Reminded of myself :D :D Keep us posted..
Started new alternator trhead, :roll:
Giulietta24vTT
Barry wrote:Chen,You scare me!!
I take it as a big complement , your jobs are superb Barry!
A bit off topic but close to the manifolds subject,a 2.0 16VT manifold I reacently built with a friend in my workshop, it's an improoved supersprint design with 20mm width head flange for 4X EGT sensors side drilled and SC40 thickness Steel with 38mm internal diam, I'm thinking of transpanting such engine with light mods in a GTV next summer.
ManifoldLanciaProject270506 005.jpg (210.59 KiB) Viewed 12275 times
Chen S
