cam questions
how do i go about identifying 'stock' cams from posible modified or 's' cams...reason i ask is well the 2.5 thats in the 83 right now wants to jump up to redline with a quickness and pulls real hard ..the only thing i know is that the engine is out of a used millano and was 'low' milage...also ive got the stock 2.5 sitting in the shop as well that has 70k miles on it but was pulled sue to exxcesive smoke..wich i later found out was due to a badly adjusted afm box as the same heavy smoke issue happend when the new engine was installed..the previous owner know little about the car and the replacement engine as he picked it up in a 'lot' deal of 3-5 alfa's about 8 years ago or so and his friends talked him out of the others and left him with this gtv wich he had little intrest in so it sat
