is power windows a posibility on the rears on a gtv-6? as in has it been done by someone or was it an option...them things are a pain to open and are sooo bloody stinking slow its almost pointless...and dont get me started on my opinions of the cable window setup
what would it take to put a set of alfetta tail lights into an 83 gtv-6?...maybe its just me but i prefer the flush-ish mounted style of them over these ungodly huge things that remind me of deloren tail lights....and does anyone have any ideas on where i might find a set?
Re-originals: 200$ for the set (4 pieces)
Fits over the body metal work just fine. Keep your old reflectors (the inside piece). Buy a few long stainless bolts that fit...drill small holes int he right spot through the old reflectors..... . mount the set-up. Works and look fine.
Also, Two types of lenses. Tops are always red. Bottoms can be red or amber. Amber tougher to get, though...
- P3170003_0001.JPG (70.95 KiB) Viewed 6244 times
I have to agree too. alfa made a mistake when they took these light out, and an even bigger mistake removing the gtv6 symbols behind the back windows, and replacing with the rubbish plastic bits, . The originals look much more exotic. Does anyone have a source for these back lights in the UK? also is it possible still to seal the assem blied from watr ingress, using the olf reflectors?
i dont mind the plastic triangles behind the back windows..well if i could get me a set of baloco clovers to put into the obvious baloco holes that is :p
anyone got a source or someone who might be parting with some of the script style alfa emblems?...ive got the huge aluminum slabs but factory drilled holes under them
