oil air seperater?
wondering what you guys do for a replacement....im fairly sure mine is toast getting tons of oil into the intake and air hoses...as well as a strange issue where the car idles realy slow and ruff but if i pinch off the tube going to the oil/air it goes back to normal till i unpinch it
i could care less about factory original just something that works as needed
The std seperator does a stirling job ...yes,we all end up with quite a bit of oil all over the intake and in the plenum..I have found though,that if the engine is in very good condition you dont have the oiling issues...
So the fix here would be to fit a 155v6 or 164 ,maybe even a 156 seperator in line with the std one.These have more volume and a nice drain back to the head for oil return..you just need somewhere for the oil to return into..
if the above is not on,go the full hogg and buy or make a new catch tank as used in racing cars...
- Giulietta24vTT
Barry , on my 3.2 NA car I've put a Greddy -like catch tank, how does it supposed to be connected?
(the catch -can has 2 tubes on top only).
The plugs cover tube's pipe? , the block's exit tube's pipe? and the nipple on the intake area?
should I put a breather and where?
Chen S
ex Giulietta 24V Glenwood TT.
i have the same ..but mine catch is home made ...one tube forGiulietta24vTT wrote:....the catch -can has 2 tubes on top only...
oil vapour(head cover) other conected to breather filter or intake past air cleaner ...here is example of DIY catch can.. very simple and very efective ...the wire things are stainles steel but dontknow engl name .. for washing very durty dishes
- CAN1.jpg (44.12 KiB) Viewed 9952 times
pic looks like a big 'crack pipe....
Shortlife....besides the oil sep hose pinch and a vacuum leak at the separater....check that the little rubber seal is intact on the oil dip stick and the oil fill cap gasket as well. Emisssions crank case vacuum fume reburning stuff.....
Or just put a filter breather ( Summit racing) in place of the separater and block the inlet on the big intake hose...not legal in most US states....no more idle problems
hey x-rad where does the small line on the oil/air filter goto? this is an 83 so it doesnt have the silly immisions canister...being its an 83 what other crank case vents should i be looking for?..i dont visualy see any but im 90% positive the engine itself came from an 85/86 milano
not to conserned about emission control issues due to the fact it doesnt have cat's under it anyway just some nice smooth "test pipes" ...even if i did have to run it thru emissions it would likely pass without the cats and any of the other "controls" since the tests here are realy simple and they dont useualy look for that stuff
Need to see a pic of this 'small tube'. I have only ever seen the attachment to the valve cover and the line to the intake. Maybe some weird emissions crap built for a short run not in the manuals????
Some pics of Milano setups...
Any other leaks besides the intake system and you would have leaking oil or antifreeze....
- img053.jpg (63.18 KiB) Viewed 9881 times
- img054.jpg (65.84 KiB) Viewed 9881 times
well what i do know on this engine is that from the valve covers up its all stock gtv-6 and from there down its all milano since i finished part of the swap for the previous owner..besides the 84+ TB wont realy work on an 83 :p
ill grab a pic if i can(its hard to see) in the morning but this small unknown line runs off a small nipple on the front side of the air/oil down tward the dist and is what looks like factory tied to the a/c lines and runs with them back to the firewall then dissapears just down and to the passenger side of the water hose lines neer the exhaust
ok i snaped of some pic's
- this is the line offf the seperator
- 1Picture 405.jpg (88.09 KiB) Viewed 9845 times
- yeah its down there..bottom left corner
- 1Picture 408.jpg (74.51 KiB) Viewed 9845 times
- here is as close as i can get to it where it vanishes
- 1Picture 406.jpg (62.7 KiB) Viewed 9844 times
