My GTV tried to pss me off
At the first lap of my qualifying (which else), the gear stick suddenly got loose. Well, lost the quali but that was not the main issue. After looking under the car to find the pin holding the gear selector to the shaft coming out from the gearbox fell off, I realized now I'm in trouble.
After a short thinkabout I and trial I found there's NO WAY to fix it at the track. Even after towing the car home for the night between the quali and race I found it would take at least 6-8 hours to fix it normally (my flat bottom is NOT exactly service friendly).
Fixing took just 2 hours or so and most time was spent protecting the windows and removing seat and belt.
After now servicing isn't that bad anymore 8)
I'll need it next time when I ditch the iso stuff.
PS! In the first picture the cure for sloppy gearbox mounts is visible as well.
Shift service 1.jpg (112.19 KiB) Viewed 6387 times
Shift service 2.jpg (121.12 KiB) Viewed 6387 times
TS_turbo
Post by TS_turbo »
Micke interesting type of roll cage dezign you have .. :) have you more detailed pics of the cage :?
Wow, isostatic, I thought you were smarter then that... :twisted:
Nice out-of-the-box fix though. :)
Noblody accused me for being smart.
Isoshift is simply left behind from '91 or so when I changed to a TS box.
It works pretty well so it's not my main concern. It will be changed some day.
Here's a couple of pics of the roll cage.
Shock tower.jpg (55.05 KiB) Viewed 6354 times
Roll cage rear.jpg (73.07 KiB) Viewed 6355 times
Roll cage front.jpg (87.51 KiB) Viewed 6354 times
No horisontal in the dash?
Two thin ones which also hold the dash in place.
Maurizio
Post by Maurizio »
:D radical but everything is allowed to enter a race at the last moment.
Me likes the cage. Nice ones the traverse over the foot well and to the back, only miss a traverse from the front (top shock area) to the bulk head.
Had something similar in mind, only want to keep the passenger seat.
