1978 gtv4 to 6 conversion
iv got the chance to pick up a cheap 90 2.5 v6, and i plan to use the engine and trans to drop into my 78 gtv.
so far iv been told it all bolts in fine, and that the engine mounts need to be moved forwards 10mm. anyone know which is correct from experience?
which tail shaft do i use? the 90's or the gtvs?
also, are the torsion bars the same length?
what problems should i expect?
1 Buy a set of V6 engine mounts, cut off the old ones and weld in the new taking careful note of location or extend the original ones forward by the amount indicated by the engine mount (on the engine).
2 Use the 90 shaft with possibly the 2 litre rear donut coupling to clutch input shaft.
3 You wil need to intergrate the ECU with your existing wiring and install an eletric fuel pump and return line to the fuel tank.
What to watch out for?
More regular invites to the policemens ball.
Dead easy.
You retain your original mount and weld the front half of the 90 mount (cut from the 90 chassis) to it. I don't have a pic with me but I'll grab one tonight and post it so you can see. ** Actually, have a look at http://alfagtv6.com/bb/viewtopic.php?t= ... b599efb5f2 **
Use the front half of the 90 tail shaft and the rear half of the GTV one. The biggest issue here is the trans tunnel size in the GTV - small ! The 90 shaft is a little different to a GTV6 one and that makes fitting that big front donut up through the tunnel a little more difficult.
The V6 rear engine mount (bell housing one) is actually about 5mm narrower than the 4cyl but that's easy fixed by slotting the holes.
Beyond that, everything else pretty much bolts in.
I retained the standard GTV radiator and it was fine.
I also retained the standard GTV trans but it only lasted a few years before spitting a few teeth from the diff planetaries (go the 75 TS) but the 90 setup is good if a little tall in diff ratio (3.55:1) and a bit of a pain to set up a speedo on (can be done - same as 75 TS swap).
You will need a GTV6 bonnet to fit the intake under unless you get (and modify) a 164 setup.
The 2.5 swap is a worthwile conversion but lots of people will ask why you didn't just buy a GTV6 (been there )
** Damn, looks like MD beat me to the post **
Go to http://www.alfetta.nl
In the Picture Book you can select Steve's Alfetta 3.5 V6, which includes pictures of the modified engine mounts. This is a 4 cyl. sedan converted to 3.5 V6 monster.
Alfetta Sedan V6
75 Milano TS Ring Racer
Giulia Squadra Bianca
'67 GT(A) Replica
'67 GT(A) Replica
How about a TS?
Hey Patzo, have you ever done a twin-spark drop-in for a GTV 2.0? I'm hoping to do it to my 1984 model sometime.
1984 GTV 2.0 twin carb
1987 Alfa 75 2.5 V6
1987 Alfa 75 2.5 V6
