Guys:
Any recommendations on which brand of FPR to use? I assume I need a 3 bar FPR - probably an adjustable one?
This is for a Glenwood 24v engine running Gotech Pro with GTA injectors.
Fuel Pressure regulator / damper?
Michael
1981 GTV6
1981 GTV6
Mike,run the std Alfa (bosch)fpr....Gta injectors are big and will work at std fuel press..
Traced bracket..goeie ou poskantoor..will mail you..
Michael,
We used the 3.7 setup on my 3.2 GTA (which we incidently just finished this past weekend with dyno tuning Friday and Saturday - I trailered it down this Sunday/Monday - it made 246 SAE RWHP). It is an adjustable fuel pressure regulator that I got from Jeg's - threaded a little pressure gauge into the regulator. That way you can always read the fuel pressure, making engine debugging a bit simpler. I can post a pic later tonight if you like.
