Front inner panel.
Hi all, after recently removing my front radiator for rebuild, I found some hidden rot in the front inner panel, that the radiator attches to. As I started to dig out the rot, I quickly realised that the panel is screwed, and needs replacing., Its only rotten just in front of the radiator, so I can weld in a new section along a contour change. Does anyone have a new or second hand good panel available, or know where I can get new ones?? Thanks all
- front panel1.jpg (55.58 KiB) Viewed 3121 times
