Just wanted a confirmation on this as my GTV6 master cylinder needs replacement.
From what I understand, the GTV6 master cylinder is 22mm, and the 164 is 24mm. That should provide shorter peddel travel and likely greater feel at the cost of higher leg pressure (not a problem in my view).
Are the two the same regarding mounting and peddel/pushrod interface/length such that the 164 unit is a direct replacement ?
Merril
Zman,Things like that are negligible to me..bend the pipe further then..Hell,Im worried when you guys have to start fitting ISUZU pickup cylinders to our cars..
