hairyblokedude
GTV6 trike more pics
Post by hairyblokedude »
More pics of the trike as requested. Much work still to do, such as getting the bugger to run on all 6 cylinders (then I'll put some sound/video on for you), bracketery for cooling pipes to radiator to make and fit, new clutch slave cylinder, front mudguard, wiring/fitting lights, bracket for header tank, fuel pump and filter, find home for ecu, etc etc...Oh, and VOSA test, MOT test...phew...
I found some plans for the front forks and stuff, dated 1990, so this trike has already spent 17 years on and off in construction before i bought it :shock:
Battery box goes over the top of the gearbox and seat fits on top of that. There is a cover that hides the remote servo, note alternater drive off of flywheel. Gearshift feels really sweet, although I aint ridden it yet...
MALDI
Post by MALDI »
It seems to have a "zero-length" drive shaft and retains the front and back guibos. A simple and direct solution!
'84 GTV6 3.0L
'81 X1/9
