Radiator fan speed
Is the standard US spec radiator fan run at a single speed? ie. on or off?
Scott
yes...and make sure it does not blow on your knees if you are standing in front of the car!
..or up your kilt for all you Scottish sports fans.. :D
What if you are Greek? :lol:
Yes only one speed.
sh0rtlife
Post by sh0rtlife »
and the best upgrade i know of is a porsche turbo set of fans and shroud...
blew fan motor and a friend had thiss assembly "laying around" 3 1 inch metal tabs up top and it was virtualy a bolt in
MD ZMAN: seriously, don't you guy's have a real life outside of GTV6.org??? :lol:
I had to "rebuild" mine....got one good fan out of 2 bad ones, the front bearings were bad on both. I took the rear bearing from one and put it on the front of the other. The fan doesn't seem to run all that fast, but its better than nothing.
I picked up a Milano fan with the 3.0 that I bought last weekend. Provided I can get the Aprilia done the GTV6 gets the 3.0 on Memorial day weekend......no i don't expect to be done, but well along.
Thanks for the help,
Scott
2Zig: there are aftermarket fans, the thin kind, for about 70-80$ that will fit as well with a little work....just don't buy a pusher when you need a puller..
even junk yard fans which you can just bring a battery and test...
obviously important to have good fan speed.
Both my fans kick on and create a very strong wind...kinda like me!
x-rad,
Are you greek too?
I've got 2- 14 inchers on the Cuda and they work well, but this Milano one came with the engine. If it isnt enough I'll go to perma-cool and try to work 2 fans in on this radiator (both pullers....according to perma-cool pulling is way more efficent than pushing)
Scott
sono italiano...
Hey Gino Radiola,
I don't know about Mr Zee but I have a regular gig at the knot hole in the fence keeping an eye on the chicks in the pool next door. On my lunch break, I get on the periscope. :D
il mio italiano è molto cattivo. ciao. 8)
brookstroutr
Post by brookstroutr »
Hey Guys,
Here's a conversion I discovered for my GTV6 radiator fan replacement/upgrade. The Maserati Biturbo twin electrical fans bolt right in. All you need to do is to:
1. Slide the radiator back and up a little.
2. Slide the bottom of the fan shroud under the radiator and install the together. The radiator locks in the bottom of the shroud.
3. I used 3 SS self tapping screws threw the top of the radiator at the fan shroud's mounting to secure.
4. I switched the electrical GTV6 connectors to properly mate.
Results. I've never seen the motor run hot even in extreme temps. The motor runs cooler with the A/C on with the fan running continuous. The shroud has rubber flaps at the top and bottom to allow air to pass at speed.
There are 2 types of these fan set ups. The spare shown on the hood of the white Biturbo is the standard ('84 to '86 I think). The one in the GTV6 is the "Tropical" version (available on the '87 - '91 US I think). One fan motor is larger than the other and is the best. I paid about $60 USD for these and they are readily available; ebay, Biturbo parters...
Biturbo-GTV6 Rad Fan Out of Car.jpg (95.53 KiB) Viewed 16814 times
Birurbo-GTV6 Rad Fan In Car 1.jpg (143.22 KiB) Viewed 16813 times
Regards,
N. G. Brooks Robinson
'84 GTV6
'84 M635CSi
