The feeling of the car is great though, it pulls hard from low rpm's all the way to redline. Definately pulls longer than with the 2.5 ecu.
Lambda readings
I'm running a 3.0 12v in my GTV6. Last summer I ran it with the 2.5 ecu and afm. A while back I came across a BMW 635 ecu and 528 afm. I have a nb-lambda connected directly to a voltmeter but I'm not sure what readings to expect. On WOT I get 0.88 which feels on the safe side
What I'm more concerned about is the readings I get with less throttle and less load. The volt can go really low like 0.15v when cruising in like 60mph. That feels dangerously lean if I am to trust the reading.
