Hi Guys Im thinking of fitting a go tech system on my gtv6 2.5 cos I got stuck with it last year which was't very nice.
But My thing is will the car be economical and fast like how it is with the bosch system.
I currantly get about 10 kms per liter which is not to bad at an average of 120 kph
Any thoughts ??
Consumption wise???
- 180.jpg (180.25 KiB) Viewed 4582 times
Re: Consumption wise???
running gotech or any other programmable efi can permit you to ran each air fuel mixture beetwen economical lean figure or performance rich mixture.nisaar wrote:Hi Guys Im thinking of fitting a go tech system on my gtv6 2.5 cos I got stuck with it last year which was't very nice.
Any thoughts ??
also you can run closed loop with a wide band...
but should be better...problably because you can ride off the Ljet air flow meter that is an obstacle to air in inlet.
if you keep Air/fuel ratio like oem L-Jet you can problably hope a little 5 hp a few less fuel per 100km...
little gains BUT:
you are ready for any improvement for future...think to it.
2 stroke addict
