brookstroutr
FS - More GTV6 Misc Parts for Garage Sale
Post by brookstroutr »
Here's a list of some more parts I don't need nor have the room. ALL are in very good to excellant condition with a couple exceptions like the windshield washer tank. Maybe somebody could use one. All are clean and inspected or I won't bother selling. Some photos aren't too clear as I'm on 'snail email'. The used parts are from low mileage '82 or '85 car. If there is a problem with an electrical part like the ECU, let me know as I cannot verify, but they were from running rusted cars.
Some parts can be used on other Models like the Milano. Buyer to verify individual use and ask any questions if you need to. Make a reasonable offer. Forums first , then eBay'm...Shipping (USPS preferred) is extra and per the instuctions Buyer. Combined is not a problem. All parts are in NE Florida 32656. PM or ring me at 904.210.9242 Bear with my response time as I'm traveling between jobs and may be sporatic on email access.
1. Bosch ECU PN 0 280 001 113
2. Bosch Ignition Box PN 0 227 100 017
3. Positive engine bay starter cable
4. Fuse Box - the wires were cut at the rear relays. This fuse box literally looks as new.
5. V6 Spark Plug wrench & container - no handle.
6. Alfetta new Brake Caliper Pins & Clip set. I think they're for the fronts and the pins are 65mm in length.
7. Alfetta/GTV6 Watts Linkage Rod End new bushing set - no center big bushing.
8. Windshield Washer Tank - all the holders are there; usual age discoloration; has a crack on the side corner and can be epoxy repaired.
9. 1 pair Front Brembo Aluminum Brake Calipers
10. New OEM Rgt Rr Tail Lite Lens
I also have an '84 transaxle w/122k miles that's just re-sealed from my car. It shifted just fine and I used Redline Synthetic 75-90 NS. There's no clutch or input rod. I will post seperate if I decide to sell. With 3 different cars, the spares are starting to turn into a severe manic bipolar moment breeding with ADHD.
FS-GTV6 Bosch ECU PN 0 280 001 113.jpg (57.32 KiB) Viewed 2398 times
FS - GTV6 Ignition Box PN 0 227 100 017.jpg (180.32 KiB) Viewed 2398 times
FS - GTV6 Positive Battery Cable 1.jpg (204.29 KiB) Viewed 2398 times
FS - Alfetta Brake Calpr Pins 1.jpg (230.59 KiB) Viewed 2398 times
FS - GTV6 used winshield washer tank 1.jpg (62.76 KiB) Viewed 2399 times
Regards,
N. G. Brooks Robinson
'84 GTV6
'84 M635CSi
