My rebuilt engine has just been started for its first time - idling smoothly and without vibrations
Are the injectors from a 3.0 interchangable with the 2.5 injectors? What about flow?
I guess I need bigger injectors anyway - the engine has balanced & polished rods, crank etc - JE high compression pistons, Cat Cams, ported polished heads, bigger valves etc....
Currently running stock L-jet - but will install aftermarket fuel injection as soon as i can afford it. Just need to drive the car from the shop that has restored my GTV6 and put it in winter storage.
Any suggestions to suitable injectors?
My car slowly coming together: http://home.chello.no/~alfator
Regards,
Tor Erik
