ingegnere
GTA engine project
Post by ingegnere »
A friend of mine bought a 147 GTA engine that we'd like to build in a GTV6. Do you guys have experience in fitting a GTA engine in a 116 car? What should be taken care of?
I've never done 24V conversation, so some online help would be appreciated. :)
Assuming that engine mounts, and flywheel fits quite straightforward, is this true regarding to oil sump as well?
-Will the sump fit with the GTA oil pump? If not can the oil pump be changed to a 75 type one?
-Shall the water pumpő be changed to a GTV one? Is yes, what about the front pulley?
-Intake plenum is planned to be kept in that assymetrical form, with the necessary welding for throttle body. But what about electrical accelerator? Can it cope with the original accelerator lever?
Just a few questions to start the discussion. Hope I will get some answers, and I can inform you soon about our results.
Thanks in advance!
'The GTV': '83 GTV6; (summer)
Oil pump,No.
Std oil pump,No
Waterpump,No
Use your std gta oil pump with a custom made sump .
Use the gta waterpump with the poly v belt and adapt your alternator to use the same belt.
You will also need the 4mm spacer on the rear of the crank.
4mm spacer.JPG (153.14 KiB) Viewed 21309 times
ingegnere
Post by ingegnere »
Thanks Barry!
Does custom made mean a whole new sump or modifying the GTV sump is possible?
Unfortunately it means a complete new sump.The gtv6 sump is made of magnesium and is very difficult(READ EXPENSIVE AND SCARCE) to modify,I just make a new sump from ally plate.If you have a 164/156/166 sump handy,machine off everything below the flange and use the flange as a base3 to make the new sump.
junglejustice
Post by junglejustice »
Balance factor changes too...
ingegnere
Post by ingegnere »
Sorry guys, but I was very busy last week.
Engine project is on it's way.
The GTA sump, and the intake plenum was modified to fit in the GTV engine bay, and the GTA flywheel is going to be used with an intermadiadte unit to fit the Hardy.
I'll post pictures, I promise! :-)
ingegnere
Post by ingegnere »
Here are two from the beginning.
The engine itself.
The engine itself.
Resize of GTV-GTA 023.jpg (109.44 KiB) Viewed 20498 times
The sump.
The sump.
Resize of GTV-GTA 026.jpg (97.67 KiB) Viewed 20498 times
Seb
Post by Seb »
Interesting project! How did you modify the intake plenum? Pictures?
I´m putting a 3.0QV from a 164 into my GTV6, maybe we run it to some of the same problems.
My thread: http://www.alfagtv6.com/bb/viewtopic.php?t=88
Seb
156 V6 24v -98
GTV6 3.0QV-83
Performance
This is how I did mine. The cold air intake comes from the back of the headlights/inside front guard.
(Resising my photo has turned out fairly poxy I must say)
If any one needs a clearer image, just mail me and I will send you a larger and clearer image.
intake mods.jpg (90.24 KiB) Viewed 20467 times
Seb
Post by Seb »
I wouldn´t mind a larger picture. Please e-mail me on, sebasian.stein@bj-konsult.se.
Did you open the side of the plenum and put the air intake there? Looks like it. I´ve been thinking about doing that too.
Seb
156 V6 24v -98
GTV6 3.0QV-83
GTV6GPTT
Post by GTV6GPTT »
same
fastcar
Post by fastcar »
Hi Guys!
Here are some new pics about the project:
Resize of GTV-GTA 028.jpg (86.2 KiB) Viewed 20215 times
Resize of GTV-GTA 029.jpg (87.97 KiB) Viewed 20219 times
Resize of GTV-GTA 032.jpg (87.44 KiB) Viewed 20219 times
fastcar
Post by fastcar »
The Intake:
Resize of GTV-GTA 036.jpg (93.33 KiB) Viewed 20211 times
Resize of GTV-GTA 037.jpg (107.8 KiB) Viewed 20212 times
Resize of GTV-GTA 042.jpg (84.59 KiB) Viewed 20216 times
fastcar
Post by fastcar »
The first time...
Resize of GTV-GTA 043.jpg (121.71 KiB) Viewed 20208 times
Resize of GTV-GTA 044.jpg (130.09 KiB) Viewed 20209 times
Resize of GTV-GTA 046.jpg (117.71 KiB) Viewed 20210 times
