viewtopic.php?f=23&t=4401
After an introduction of myself now an introduction of the enige I want to install into my 75 model.
The engine is:
- 3.0 V6 bi-turbo motor, 164 12V modified to transaxle
- Two turbos Garrett T25's
- 2 Intercoolers
- 1 very fat new race radiator, cools to 400 Pk
- Turbo spruitstukken
- Aeroquip and SAMCO connections/flanges
- Water injection, Aquamist
Modification:
- Flowed heads
- Two Colombo low pressure camshafts
- Standard Compression (maybee later modified to 8,6)
- Special valves siliciumbronze coating
- Crankshaft weighted, balanced, polished
- (Later low compression pistons)
There is no clear wiring and engine management.
Later, I 'll try to put some pictures on the web.
Inletlines. From compressor towards intercooler and plenum.
Six bobines
Exhaust pipes towards the Turbo's
Big fuel pump
Cooler with extra width
