Wheel Adapters
I can do any stud pattern with any cantre spigot diameter (62mm and up - standard Alfa spigot is 58.5mm), annodised in any colour for $500 (Australian) per set of 4 including studs, wheel nuts, countersunk bolts and nuts. Minimum thickness is 14mm front and 20mm rear, more is possible.
- Rear adapter
- 08-02-13 002.jpg (101.41 KiB) Viewed 2130 times
- Front adapter
- Stud adapter.jpg (122.14 KiB) Viewed 2130 times
