Installing MS 3.57
Hi!
I'm just finishing my install using a pre-built MS1 3.57. I've followed the MS > L-Jet drawing when building the adaptor for using my existing LJet-harness. I also bought a db37-pigtail to make life easier.
I have two groundcables coming from the db37-pigtail. I just ground them to the Ljet-casing, right? Also I'm supposed to ground Ljet pin28 to the same point?
Am I missing something else or am I good to go?
Also, I would like to run MS-Extra with mapdot to start with. Any special code needed or is it ok with current MS-Extra firmware?
Regards
/Marcus
Regards
/Marcus
Hi Marcus, do you have any pics of your MS11 install? I have a MS11 v3 to install in my GTV6 3.0L but dont know where to start so any help would be greatfully accepted.
email: paulbird666@live.co.uk
Cheers
Paul UK
Cheers
Paul UK
Paul, It's not that much to see really, but I recommend you to slaughter an ljet-box to build the adaptor and also to get the db37-pigtail. As you can see there's still a few wires to be soldered. Hopefully I will just plug in the MS and start tuning soon
Here goes:
Here goes:
- cam 037.JPG (51.61 KiB) Viewed 20025 times
Hi marcus, that was a quick reply, thanks. I have already got a gutted l-jet box ready to go, I just need to do the soldering. I have a schematic from Steve Rosser but I am no electrical wizard, I like to work from photo's as well as drawings. I also have a DB37 pigtail. I would like to make the transition form l-jet to MS11 as easy as possible.
Cheers
Paul UK
Cheers
Paul UK
Yes, I have. Here they are.
- ljet-to-ms.pdf (19.6 KiB) Viewed 19938 times
- MS LJET Interconnect.xls
- (17.5 KiB) Downloaded 919 times
I'm sure you'll figure it out. If you check the backside of the ljet-connector you'll notice that every pin is numbered. You don't have to worry about the MS-pins since you have the pigtail with labeled wires, right? If you use the excel-document you'll only have to match for example, the CLT (coolant temp sensor)-pigtailwire to pin13 on the ljet-connector. Solder the most obvious first and check twice that you connect them to the right ljet-pin.
/Marcus
/Marcus
