Sad to mention summer is almost over here and I will have to place the GTV6 (1984) into the storage. I did not have too much chance to drive it this summer
We have replaced a clutch assembly. I think I mentioned in the previous posts that we adjusted the shifter such that shifting became very smooth. But after a week of driving I heard, squeeking noise from the clutch -- during shifting (the time when clutch pedal is half pressed and I change the gears), friction ? Then the sound become worst when I pressed the clutch fully to the floor -- rattling sound. We though it must the the release bearing on the clutch. I got the new bearing installed it, and 2 days after simillar problem. At this time we are stuck, no idea where to check next...Any help would be appriciated, thank you
Michal
