nisaar
More turbo isuues
Post by nisaar »
Hi there does any one know how to connect these turbo carbs
No 1-- Is the blow through where does it connect to ?
No 2-- Is main fuel
No 3-- Is Regulator
My first question is where do you connect the fuel return to ? (on the carbs)
My second question is where so you get air to pressurise the blow threws?
It got me stumped these are DHLA4 H carbs :roll:
According to the alfa mecs it needs a high pressure pump
Re: More turbo isuues
It's carbs, there is no fuel return.
I'd say you need to connect the #1 connectors on the covers of the carbs to manifold pressure, to get the right pressure diff in the carbs. Dellortos right?
nisaar
Post by nisaar »
Ok kewl that makes sense there is that blocked off pipe ontop of the manifold I will connect that to the blow through should that be enough pressure ??
I would think so. Have never dealt with turbo-carbs myself but that's the info I have. Make sure you try everything outside and with an extinguisher ready.
No, I'm not joking! :shock:
nisaar
Post by nisaar »
Ohyes I always do
I had an episode with my ford sapphire wasn't nice belive me it was fuel rail ->distributor -> fire runnning around -> can't find extingusher, I found a 20lt drum of dish washing liquid I put the fire out but the harness was toast
