Clutch fork grease
.. as it says, what grease do I use to lubricate the fork and pivot area?
Re: Clutch fork grease
If available in your Country, I'd suggest the one used in the factory, that's to say AGIP 33FD.
Regards
Oscar
Regards
Oscar
Bruce for applications like this I've always been happy with the results I get using Mercury outboard marine grease.Sounds funny but this stuff is sticky and hangs around a long time.It resists getting washed away .You can buy it in small tubes wherever they cater to boat people.
similar to what murray suggested is Bel-Ray Salt Water Proof grease. Sticky thick and water resistant. Available at most motorcycle shops.
Marine grease eh? I'll give it a shot, thanks for all your inputs.
I use Dirty Dan's Hand Packed Super CV Joint Grease.
