Terry Johnston
Rear Sway Bar Links
Post by Terry Johnston »
Does anyone have a schematic of the sway bar links for the an 83 GTV6. It seems different than the schematic for the Milano. Mine is a shankle sway bar and the link looks like a long bolt not the type with a u bracket where it connects to the sway bar. I want to make sure that I have the link assembled proberly. Terry
Terry
JoeCab
Post by JoeCab »
Terry,
Yes, you are correct the GTV-6 style end link is a long bolt with bushing on both ends while the Milano uses an end link that is forked at the top.
Joe
Paul Bird
Post by Paul Bird »
Terry, I have these made out of stainless steel and use polyprop bushes and have found they work relly well,
Cheers
Paul
84 GTV6 3.0L CB cams
