Alfetta wheel offset
Am I wrong or right?
Alfetta 1978 sprint v.
offset: +35mm
hub centric dia.: 58.5
4 x 98
offset: +35mm
4 x 98
Re: Alfetta wheel offset
The Alfetta offset is more like mid twenties. My stock 6" rims came with 22mm offset. The GTV6 folks speak of stock for their cars as high 30s or low 40s. I think there must be a difference in the width of the car (wheel mounting points) of a cm or so between the Alfetta and the GTV6, because I placed some 38mm rims on my Alfetta and they just sat way too far in on the car.
The rest is correct.
Stefano, Concord CA
74 GTV, 79 Alfetta GT
iachella [at] gmail [dot] com
thanks!
18racing sells nice set of rims but with 35mm offset...might stick out too far...maybe..
I think the actual offset is 40
There should be absolutely no problems with 35's
I really like these:
come in +35, 4x98, several colors, size 15x7, 58.5 center
- rb_1.jpg (23.42 KiB) Viewed 20819 times
Again, that is the case with GTV6s. The Alfettas are in the mid 20s.I think the actual offset is 40
The more the offset, the more the wheel sits in, so 35mm would not stick out too far, but would sit in too much. I'd put 5-8mm spacers on those wheels.
I have those wheels on a GTV with 30mm offset and I put 4mm spacers. That made them pretty much perfect. My Alfetta has ATS Classics with a 16mm offset. They seem just a hair too far out so I may mill off a few mm at the next tire change.
Stefano, Concord CA
The hub is 58.6mm.
Stock gtv6 offset is et45.
There is no differences between gtv6 and 4 cyl gtv, the track is identical. 4 cyl ran the same wheels as the gtv6 on equivalent models. the earlier 4cyl used 5.5 x 14 speedlines also with et45.
Dealers may have fitted different sorts of wheels - I had a 79 gtv with some wierd 6 x 14 wheels that were et25 and stuck out in the guards and increased the track width - steering was not so good with these either.
My gtv6 now runs 7.5 inch rims with et35 and they fit with 205/45 17 tyres (which is close to standard dimensions).
Some offset changes are not legal in this country as you can only increase the track width by a certain amount (I believe it is 25mm, or 12.5mm per side).
Jason
1983 GTV6 2.8 litre
1983 GTV6 2.8 litre
I would still disagree with the Alfetta specs. Mine came with factory (not dealer) wheels at 22mm offset, as well as every stock Alfetta I've seen in California. Maybe Alfa had different specs for different areas, who knows.
Stefano, Concord CA
In Europe the stock ET was 45 as well.
My aftermarket wheels were ET28 and they come way more out than the stock steel ones.
I put +35 offset on the GTV6 and they fit perfectly. Since there is a slight difference of opinion on the offset for the Alfetta 2.0, I will try to measure.
Thanks for the replies!
58.6 ...got it.
58.6 ...got it.
I've never been to California, but don't know of a 'factory' alloy other than the Turbina, which is 5.5x14 et45 (and does make them seem very narrow tracked).iachella wrote:I would still disagree with the Alfetta specs. Mine came with factory (not dealer) wheels at 22mm offset, as well as every stock Alfetta I've seen in California. Maybe Alfa had different specs for different areas, who knows.
Below is a listing that I found on the net at some stage:
Wheel Offset
Here you can see a table with the original off-set sizes:
105 4x108 PCD
Giulia (4-d) 42 mm
Bertone (63-76) 38 mm
Spider (66-93) 38 mm
AR Berlina 38 mm
Montreal 25 mm
Sud 4x98PCD
Alfasud Serie 1 45 mm
Alfasud Super 45 mm
Alfasud ti Ser2 39 mm
Alfasud Serie 3 39 mm
Sprint (Sud) 39 mm
116 4x98PCD
Alfetta, all 45 mm
Giulietta, all 45 mm
Alfa 33, all 39 mm
Alfa 75 1.6-2.0 45 mm
GTV 2.0 45 mm
Alfetta GT/GTV 45 mm
116 5x98PCD
Alfa 75 2.5 45 mm
Alfa 75 TS/Turb 30 mm
Alfa 75 3.0 30 mm
Alfa 90 2.0 45 mm
Alfa 90 2.5 45 mm
GTV6 2.5 45 mm
New 5x98PCD
Alfa 145/146 1.4/1.6/1.7 16V 43 mm
Alfa 145/146 T. Spark/Q/ti 50 mm
Alfa 155, Serie 1 (first model) 50 mm
Alfa 155, Serie 2 (wide aches) 41 mm
Alfa 156 41 mm
Alfa 164 TS/V6 40 mm
Alfa 164 24V 32 mm
Spider T.S./V6 35 mm
Spider V6 24V 31 mm
GTV T. Spark 35 mm
GTV V6 24V 31 mm
But then there is the additional thing about bolt circle.
Old Alfas have 4x108 mm.
Alfasud/33/75/90/145/146 have 4x98 mm
Big engine (TS, Turbo, V6) 75/90 have 5x98 mm
147/156 have 5x98 mm
166 has 5x108 mm
The center hole has a diameter of 58,6 mm, but from the starting of the Fiat aera (1987) this size changed on new models to 58,1 mm.
If you find a new wheel which fits on a new Alfa, and you would like to use it on your Alfa 33, then you have to enlarge the center hole by 0,5 mm.
Jason
1983 GTV6 2.8 litre
1983 GTV6 2.8 litre
Slight OT but I gave some wheels to a friend as I knew they fit his 75.
He got them on allright but getting them off was a hell of a job. Seems they were 156 or 147 with the smaller center hole.
Hmm... I'm going to have to do my own research to convince myself of those high offset values. Those are like FWD figures. Hard to believe.
Stefano, Concord CA
What does it matter anyway?
I wouldn't use stock ET whatever. The wheel thread has tons of info. Anything from ET0 to 50 might be OK for you.
