IMSA 75 detailed pics (original factory car) at Swartkops SA
im going to start posting a whole bunch of pics of thsi awesome car. One thing for sure is that its faster than our big twin turbo v6 race cars on this twist Swartkops Circuit. Depending on boost its capable up to 400hp. I wont say they were exagerrating either as it was hammering most BMW's , Fords with 200hp more.
In these pics there are some interestng concepts we can do in our own cars from simple things like their heel toe pedal set up etc.
Probably about forty pics altogether. Just some to start off.
- 75 gearlever.jpg (28.35 KiB) Viewed 13855 times
- 75 gearlever top.jpg (22.44 KiB) Viewed 13855 times
- 75 heel toe pedal.jpg (27.25 KiB) Viewed 13855 times
- 75 int font of radi.jpg (32.13 KiB) Viewed 13855 times
- 75 lower cont 2.jpg (28.53 KiB) Viewed 13855 times
Re: IMSA 75 detailed pics (original factory car) at Swartkop
Mats check the intercooler behind the radiator. I will post more tomorrow. just to keep you guys on line.
- 75 front.jpg (39.57 KiB) Viewed 13854 times
Is this a Dutch car bought by a Sarf African?
Is the rear suspension a solid modified dedion, fully independent or that complicated dedion/independent stuff like the one in the Museo Storico?
Z its car no 14. Brought to SA to race in a touring car series from holland. Its Harmen Van Putten car. Really great guy who loves Alfas.
Regarding more pics - keep your shorts on. There will be enough pics to build one yourself
Those IMSA's were absolutely the most exciting thing to see racing here in Holland.
Just loved the flames in the overrun and at shifting.
There can be no such thing as to much pictures from these cars...
So keep on posting them.
Z, there were two types of rear dedion for the imsa This must be the early type ie more solid type.
I've seen that car race quite often then... Harmen is indeed a very nice guy. he has (had) several nice Alfa's.
Some more pics.
- 75 carbonfibre prop.jpg (20.59 KiB) Viewed 13810 times
- 75 bellh4.jpg (27.42 KiB) Viewed 13810 times
- 75 bellh3.jpg (28.77 KiB) Viewed 13810 times
- 75 bellh1.jpg (25.12 KiB) Viewed 13810 times
- 75 antiroll.jpg (25.74 KiB) Viewed 13810 times
See the bellhousing which bolteded onto to rubber mounts above. the engine is bolted solid with no rubber. Center section is cutout to accomodate one piece carbon fibre prop. It still uses rubber coupling upfront with a cage and cv in rear.
- 75 dedion1.jpg (22.32 KiB) Viewed 13810 times
- 75 dash.jpg (28.72 KiB) Viewed 13810 times
- 75 chassis number.jpg (20.37 KiB) Viewed 13810 times
- 75 centrecut2.jpg (26.38 KiB) Viewed 13810 times
- 75 center cutout.jpg (23.26 KiB) Viewed 13810 times
Will post lots of detail pics of dedion next week. Interesting stuff to look at, see solid engine mount. These guys were running up to 2bar boost.
- 75 front pulley.jpg (28.77 KiB) Viewed 13810 times
- 75 front pads.jpg (28.17 KiB) Viewed 13810 times
- 75 front caliper.jpg (20.92 KiB) Viewed 13810 times
- 75 exh1.jpg (25.15 KiB) Viewed 13810 times
- 75 engine mt.jpg (23.08 KiB) Viewed 13810 times
more pics
- 75 gearbox.jpg (29.57 KiB) Viewed 13689 times
- 75 gearanddash.jpg (29.02 KiB) Viewed 13689 times
- 75 fuel setup.jpg (27.58 KiB) Viewed 13689 times
- 75 frontcouplingcage.jpg (19.88 KiB) Viewed 13689 times
- 75 front shock mt2.jpg (25.77 KiB) Viewed 13689 times
After the clutch unit this gearbox is wider than the stadard box.
- 75 gearbox rear.jpg (26.21 KiB) Viewed 13688 times
- 75 gearbox mt.jpg (29.51 KiB) Viewed 13688 times
- 75 gearbox breathjer.jpg (29.76 KiB) Viewed 13688 times
- 75 gearbox 3.jpg (25.03 KiB) Viewed 13688 times
- 75 gearbox 2.jpg (25.05 KiB) Viewed 13688 times
Mats , if you can get your GTV turbo set up like this then you have hit the holy grail on the head. Knowing you , you going one better. Check the size of this turbo
- 75 turbo manifolds.jpg (28.88 KiB) Viewed 13646 times
- 75 turbo close up.jpg (27.51 KiB) Viewed 13646 times
- 75 stub top view.jpg (21.79 KiB) Viewed 13646 times
- 75 stub front.jpg (27.24 KiB) Viewed 13646 times
- 75 me trying to reverse.jpg (34.1 KiB) Viewed 13646 times
Few more, still trying to sort them out on my phone. Comments welcome on this thread.
- 75bellh2.jpg (26.03 KiB) Viewed 13646 times
- 75 watts linkage.jpg (17.92 KiB) Viewed 13646 times
That is one awesome car. I would like to hear more about the forward Guibo, driveshaft and transaxle.
Is the forward Guibo an alfa part? Did all the IMSA cars run a carbon fiber driveshaft? What mods does the transaxle have to handle the power? If it has 400hp at the flywheel, it might not need any, but it would be marginal.
