See pics - this is an example of the extensions used in one of our local cars - would love some thoughts, opinions and other ideas???
WHEEL ARCH EXTENSIONS
Hi
- wheel ext 4.jpg (105.16 KiB) Viewed 11242 times
- wheel ext 3.jpg (119.72 KiB) Viewed 11242 times
- wheel ext 2.jpg (137.57 KiB) Viewed 11242 times
- wheel ext 1.jpg (134.46 KiB) Viewed 11242 times
Re: WHEEL ARCH EXTENSIONS
I like them... Because they are not to wide they don't really destroy the original design. are these from another car? plastic or metal welded in?
I've seen that old VW golf mk 1 rear wheelarches are quite similar in look and design to the rear arches of the GTV, and also a bit wider so maybe that's an option also.
These are fiberglass arches , just handcrafted to suit .
Ben erg benieuw hoe dit is gemaakt.
Groet Jeroen
Groet Jeroen
Okay , I will find out when I go to Swartkops on saturday .
