Someone has killed my car!!
Car has done approx 30-40000km on these mods, it’s all in good condition.
Serviced every 5k with Edge 25-50 and twin valve genuine filters.
I don't have time or $$ to fix it up this time, pick-up a bargain!
Engine gearbox/diff has been fully rebuilt as pictures show, cams alone cost $2000!
Fully balanced and lightened engine with milled flywheels (front and back) – new clutch.
Heads machined and bored to suit cam.
Custom headers and pipe work with SS rear muffler..sounds amazing..I promise that!
LSD was built by Perkings engeeniring with 47% lock, all new clutches.
Brakes are modified Volvo 4 spot with a larger master cylinder on modified 164 rotors.
Rears were rebuilt with new rotors.
Koni yellow, one is busted up!
K-mak race swaybar and 105 ball joint castors never fitted.
Poly rear links.
Blah..Blah ..look at the pics, I spent well over $15k on these mods over the years.
All built by a very experienced Alfa mechanic, this mechanic is willing to put this engine in your car and if he does I will guarantee all the parts to be working 100% and as listed.
Car was never used as intended (to be raced) it always lived with the standard 3.0L Jet-tronic so it never revved passed 5400rpm, I do however have a dual sport ecu that was never installed (will need to be installed and put on a dyno).
I will include the original 3.0L gearbox with the LSD and heaps of spares..heaps!
The boot is full and I have more hidden.. One new spare mag is in the box.
Inside its clean and stock with a nice Momo club 4 steering and a solid SS gear knob.
This sale is for the full car, it does start however the oil filter has a hole and sprays oil everywhere, hard to replace as there in not much room there now.
The only damage to the engine is a cracked air-con mount on the oil-pan..Yes I like air-con in my cars – This does not compromise the engine in any way thou.
Pick-up from the Parramatta area in Sydney.
$5k for the lot.
I can send more pictures if requested.
Please only serious interest as I have little time these days.
Cheers.
- Que Boludo
FS Alfa 75 Race Modified 3.0L Gearbox/diff Brakes and Susp.
- DSC01133.jpg (69.61 KiB) Viewed 9048 times
- DSC01125.jpg (84.07 KiB) Viewed 9048 times
- DSC01091.jpg (43.97 KiB) Viewed 9048 times
- DSC01082.jpg (26.64 KiB) Viewed 9048 times
- 102_6698.jpg (61.34 KiB) Viewed 9048 times
- Que Boludo
Re: FS Alfa 75 Race Modified 3.0L Gearbox/diff Brakes and Su
More Pictures..
- DSC01382.jpg (61.45 KiB) Viewed 9047 times
- DSC01287.jpg (64.58 KiB) Viewed 9047 times
- DSC01143.jpg (66.32 KiB) Viewed 9047 times
- DSC01138.jpg (73.46 KiB) Viewed 9047 times
- DSC01136.jpg (71.95 KiB) Viewed 9047 times
- Que Boludo
I think you get the point now..
- DSC01431.jpg (71.76 KiB) Viewed 9046 times
- DSC01394.jpg (61.37 KiB) Viewed 9046 times
- DSC01384.jpg (66.97 KiB) Viewed 9046 times
