Ivan Boshoff
GTV6 rebuild
Post by Ivan Boshoff »
I have slowly been rebuilding a 1982 GTV6 over the last few years, I am now at the point where I am sorting the electrics. I am currently trying to hook up the power module for the injection system and distributor, unfortunately this was not labelled when disconnected and am now struggling to find what wires go where as the six connecting points are not numbered the wiring diagram does not show numbers on the module either.
Cheers
Ivan
Re: GTV6 rebuild
Hi Ivan , the light was not good when I took this pic but it might help . My car is in storage but I'm sure some else might have a pic of this .
Ivan Boshoff
Re: GTV6 rebuild
Hi Kevin, thanks for the pic, the part i am struggling with is the Bosch module next to the coil, as the bottom where the wiring goes in is not numbered and on the wiring diagram it does show numbers but not which is top or bottom however the wiring that you sent me of coil and distributor has helped.
Cheers Ivan
Ivan Boshoff
Re: GTV6 rebuild
I have replaced the ignition module and still no fuel to injectors and no spark, what to look for next ?
