Alfa Romeo Championship at Brands Hatch
Nice mix of cars:
75 3.0 12V (Snowdon)
75 3.2 24V (Kev, I think it's your mate's car)
156 3.7
156 2.0T (Lampredi 16VT)
From Snowdon's car:
https://youtu.be/SogrZXV_w8I
From 156 Q4:
https://youtu.be/9pEYbmj30U4
156 3.7
From Snowdon's car:
From 156 Q4:
Re: Alfa Romeo Championship at Brands Hatch
I must post pics from the day . The silver 156 pushes 450hp from the 155q4 motor through a Baci box . The blue Gta is a 3.8 L 24v .
George in black 75 drove brilliantly as that was his 5th race only in a car ... However is has raced karts at a very high level . Snowden is a legend as he was about 30 hp atleast down on the black 75 .
In qualifying a twin spark GTV got airborne and cleared the tyre wall but got caught in the catch fences directly in front of us . Pretty scary stuff . Driver was ok .
Some pics of the 450hp 156 with Baci box
- image.jpg (121.28 KiB) Viewed 12778 times
- image.jpg (104.99 KiB) Viewed 12778 times
- image.jpg (119.65 KiB) Viewed 12778 times
- image.jpg (121.1 KiB) Viewed 12778 times
- image.jpg (108.64 KiB) Viewed 12778 times
Pics of the 75s
- image.jpg (115.04 KiB) Viewed 12778 times
- image.jpg (128.18 KiB) Viewed 12778 times
- image.jpg (98.43 KiB) Viewed 12778 times
- image.jpg (133.61 KiB) Viewed 12778 times
- image.jpg (103.29 KiB) Viewed 12778 times
Other cars at the track including spectator cars ( my GTV and neighbours 75)
- image.jpg (129.26 KiB) Viewed 12778 times
- image.jpg (114.93 KiB) Viewed 12778 times
- image.jpg (119.47 KiB) Viewed 12778 times
- image.jpg (99.51 KiB) Viewed 12778 times
Some more pics of a really beautiful stratos that Richard Melvin brought along . Was hoping he might be racing his Napolina GTV
The metallic green sud was pretty quick as I held off a 355 Ferrari challenge prepared car for a few laps . Sud was 1800 , steel crank and rods with 48mm carbs .
- image.jpg (107.29 KiB) Viewed 12778 times
- image.jpg (118.8 KiB) Viewed 12778 times
- image.jpg (123.22 KiB) Viewed 12778 times
- image.jpg (98.8 KiB) Viewed 12778 times
Some more pics of George's 75 . Amazing to see a rear wheel drive transaxle nearly lap the 147gTA 3.2 also on full slicks . The 75s carry far more corner speed .
- image.jpg (125.84 KiB) Viewed 12778 times
- image.jpg (128.89 KiB) Viewed 12778 times
- image.jpg (118.09 KiB) Viewed 12778 times
Some pics of the GTV that came flying towards us . It totally cleared the tyre wall and was caught in the high fences . These fences absorb so much energy that totally saved the driver . He clipped a 147 entering Paddock hill which got the back out and actually gave it enough sideways momentum to start it tumbling .
- image.jpg (99.99 KiB) Viewed 12742 times
- image.jpg (246.02 KiB) Viewed 12778 times
- image.jpg (166.14 KiB) Viewed 12778 times
- image.jpg (241.3 KiB) Viewed 12778 times
- image.jpg (232.62 KiB) Viewed 12778 times
ouch poor last car and owner
You can find stop motion vids on youtube of this guys head sticking out of the window when the car was flipping. Scary! Having a window net/mesh has some merit!
BTW Kev, what kind of ECU is George running? Emerald? Seems like a popular choice for Alfa V6 owners in the UK. What about engine mods?
Chris Snowdon drives the pi&& our of that 75. Apparently it's a road registered (license plate) car belonging to his daughter.
George's 3.2 is running Omex . The motor has not even had its heads off since it was pulled from a low mileage scrapper thus it's absolutely standard . But it has light flight wheel , long 42mm primaries ( same length jk ) , tapered plenum . Makes 270hp which is about right for standard engine with those extra external mods . The clutch is a twin plate GTV 6 clutch as they handle more power than single plate and ..... It's lighter when using two four paddle organic unsprung plates . As these plates are thicker by 1 mm over the standard Sachs plates the intermediate pressure plate was skimmed 1mm each side in a lathe . This is what we did in SA many years ago so hence encouraged George to go this route . If you wanted a made up harness and map I'm sure George would make you one .... At a price
Prop is standard with cage up front but front suspension is totally custom . Done extremely well Mr George but he is still moaning about huge under steer so more work to be done . Fix that up and some nice cans , up the compression and you are atleast a few lengths ahead of the Ferrari challenges which were only a second faster . Scary thought how good the 75s are . I will post some pics of it .
Snowdens 75 runs Richards close ratio box which matches his power perfectly .
