16" Compomotive MO wheels wanted
I'm looking for a set of 16" Compomotive MO wheels, preferably 7.5x16", pcd 5x98 or 5x100, any color, in excellent condition. These are what I'm looking for: Image
Re: 16" Compomotive MO wheels wanted
Hi Jim,
No mention of offset. Is that important to you for your application?
The other thing is if there is a shortage of these wheels in the PCD of your choice, would you consider changing hubs for a more common PCD? Bit of work I know but at least in Oz, the Alfa PCD is a very limited market.
Cheers.
30-35 offset is fine and if not 5x98 pcd, 5x100 will do, which is much more popular as its for Subaru and others. No other pcd is practical as I have 2 more Alfa pcd sets at home -trying to cover my two 75's with road+trackday wheel/tire sets. I've contacted Compomotive, but they won't be making them any time soon... :(
Yeah I guess you will either increase the bore of make up adaptors to locate the wheels. I know that you know but others may not so I will take the opportunity to advise readers that using only the bolts to locate wheels generally is a bad idea. It is important that the wheel rim is located on the bore.
Ex Nissan Skyline
16x7 35 offset PCD 114.3 Needs hub conversion.
Has a similar look
Made in Japan.
Kumho tyre on rim.JPG (117.55 KiB) Viewed 9219 times
