Alfaaa1
Wanted. Alfetta GTV Rear spring lower rubber base
Post by Alfaaa1 »
Hi ,
I am after Alfetta GTV Rear coil spring lower rubber bases.
Hard to find these days , do you know where I can buy them new :(
Screen Shot 2021-10-25 at 3.22.02 pm.png (43.84 KiB) Viewed 6456 times
Re: Wanted. Alfetta GTV Rear spring lower rubber base
If you haven't found an original part by now then this might help.
Just source a thick walled ordinary garden hose. Cut a length equal to the circumference of your spring. Make a split cut along the length of the off-cut piece. Wrap it around the spring base. If it requires it, use some light cable ties to secure the wrap onto the spring base. Reinstall spring.
This is not a critical component and all you are trying to do is avoid the metal to metal abrasion and this approach will do that.
Alfaaa1
Post by Alfaaa1 »
Hi MD,
EB Spare UK has got them in stock now.
