Alfaaa1
alternator charge cable
Post by Alfaaa1 »
Hi to all.
On the Alfetta GTV 4 cylinder series.
Just confirming, the charge cable wire on the alternator goes to the starter motor positive post the same one that the battery positive cable sits on. :?:
I am starting to re wire the engine harness to suit the v6. :)
Has anyone fitted a Gotech Pro x stand alone ECU to there V6 with the original coil packs.
This is the year that I will have this project finished .
IMG_5989 (1).jpg (98.62 KiB) Viewed 6288 times
IMG_2456 (1).jpg (156.53 KiB) Viewed 6288 times
Re: alternator charge cable
Very nice progress.
The B+ output from the alternator can go almost anywhere where there is a B+ connection. However due to the fairly high current that may be produced by the alternator, it is generally connected where there is high current carrying wiring already ie. the starter B+ connection. Particularly so, if the battery is in the boot (trunk).
Alfaaa1
Post by Alfaaa1 »
Thank you MD.
