Alfaaa1
Gotech Pro X
Post by Alfaaa1 »
Merry Christmas to all,
I am using the original Alfa coil packs on my V6 Busso.Firing order 1-4-2-5-3-6
Does anyone know how I can check if this firing order is programmed in my Gotech Pro X.
KevinR
Re: Gotech Pro X
Post by KevinR »
I’m also running same ecu on my 24v . There are loads of base maps for that engine for tbe gotech pro x. Are you running cam angle sensor ?
Alfaaa1
Re: Gotech Pro X
Post by Alfaaa1 »
Hi Kevin,
No ,I was told I don't need to,it runs 3 ignition batch phases under mode 4.
I have just wired it up and when I try to start the engine it back fires and won't start.
Do you know how the firing order is programmed .
Firing order on the Busso
1-4-2-5-3-6
KevinR
Re: Gotech Pro X
Post by KevinR »
Firing order is all pre programmed. I’m not running can angle sensors either . I think you’re on throttle bodies your map will be different to mine . This will start your car
Alfaaa1
Re: Gotech Pro X
Post by Alfaaa1 »
Hi Kevin,
These are my settings ,
My TPS is now 4.9
Can you see any of my settings that are inc and won't let my engine start?
Alfaaa1
Re: Gotech Pro X
Post by Alfaaa1 »
To change the setting is a bit hard , I need to Know which keys to press. :oops:
KevinR
Re: Gotech Pro X
Post by KevinR »
I downloaded the whole manual . Also there is a help menu once you’re switched on . I know a few guys who really good with this but they are on holiday at the moment .
See this link as it all should be here
https://powermods.co.za/Pages/Downloads.asp
KevinR
Re: Gotech Pro X
Post by KevinR »
Pages 1-5
KevinR
Re: Gotech Pro X
Post by KevinR »
Pages 6-10
KevinR
Re: Gotech Pro X
Post by KevinR »
Pages 11-15
KevinR
Re: Gotech Pro X
Post by KevinR »
Pages 16-20
KevinR
Re: Gotech Pro X
Post by KevinR »
Last pages
Alfaaa1
Re: Gotech Pro X
Post by Alfaaa1 »
Hi Kevin,
Thank you for the manual its going to help. Fantastic :)
Would you have photos of your mapping for the fuel and ignition.EG refer photo attached
I have fuel at 55 PSI going to the injectors but when I crank the motor it seems the injectors are not spraying.
Electrical to the injectors are correct.
I think the programming mapping on the ECU is incorrect.
Screen Shot 2022-12-28 at 8.05.27 am.png (125.96 KiB) Viewed 10925 times
Alfaaa1
Re: Gotech Pro X
Post by Alfaaa1 »
Got the engine running :) ,
Just got to work out the idle on the Gotech Pro X ,
Will have to adjust the throttle positioning sensor.
Any advice would be great. :|
Alfaaa1
Re: Gotech Pro X
Post by Alfaaa1 »
Hi Kevin.
Could you please show me your settings on your mapping graph on the fuel and ignition on your car ,
My snap shot shows 2.44MS and yours shows 0.17MS.
My engine is running so rich and its back firing at times.
I think my settings are too rich.
I cannot take the GTV to a dyno yet.
I just want to get the engine tune to an acceptable level so I can drive the car. :(
