*This does not mean that I will be taking my questionable lightened gearbox to track events*
75 roll cage
I found a person to help me make a roll cage for my car. I am wondering if anybody has links to photos of existing cages already installed in cars?
This is from a Spanish rally car, i´m going to ask him for some schematics, i´m going to start something like that in the summer.
http://www.aunaocio.com/zonaweb/jpaul
On the left menu select "álbum de fotos"
I actually have a 3D CAD model of a 75 roll cage...
If you want, I can do some renderings for you, it's easy enough to add/remove tubes in the virtual world too.
I can even estimate weight.
Yes, UG.
.dwg is only 2D as far as I know, I could do a drawing but the cage is really only a "sketch NUFO" so it can't really be used for manufacturing. But if you want a sketch with approximate lengths that could be arranged.
I'll have a look and see how presentable it is before I post it.
Might snap some pics of the actual cage I tried to copy, that might be useful to explain it better.
Oh, I found some pics...
- Front part only
- 75-cage1.jpg (73.84 KiB) Viewed 12932 times
- 75-cage2.jpg (72.9 KiB) Viewed 12930 times
I'll complete the cage and then make some prt/igs/step files for you, ok?
Just don't expect me to have it done by tomorrow...
Maurizio: This is from when I was still building on the 75 body (that is now just standing around) It's really only a min-spec cage (not even that since the back half is still not done) that I threw together from measurements from a friends 75 cage.
I did it for a stiffness study; "What happens if I add a tube here" type of thing so the measurements aren't really spot on but rather coarse since I really only want to see better/worse kinda results and weight approximation.
- Maurizio
@mats, the parts wich are not designed yet, are the parts I want to really play around with.
For the back and the front (from the bulkhead) I have some ideas going through my head.
And since your start is parametric I can alter to verified dimensions.
So I'm not blaming you when the pipes don't fit
I have a tube bender laying around. If I get the time....
Banned.. ?
Daily donky.. ==> BMW 325d
E36M3 (3.0) Ringtool
==> definitely BANNED!
