Is there even a faint possibility that I can get some help with the MS stuff without getting "helpful links" or technical mumbo-jumbo posted in the replies?
What I miss is the facts that is actually useful to me, info like
"Fuel calculations based on mathematical equations and physical formulas relating directly to your vehicle - many other existing systems rely soley on trial-and-error, estimation or guesswork for fuel delivery." or
"Input triggering for injection events is derived from an existing ignition system - either by connection to a conventional Kettering ignition coil (- terminal) or by using the TACH signal available from virtually any OEM or aftermarket ignition system. MegaSquirt uses an on-board opto-isolator to prevent damage due to inductive kickbacks present on ignition coils." is just a stupid/fancy way of saying "It can control fuel" and "It can detect almost all types of rev signals"
This is the way it is on ALL forums about MS and there is always just bits and pieces of info and millions of cross links back and forth. Frustrating indeed...
-So, what can MS do in it's standard form. (2.2 or whatever it's called)?
-What is needed to control spark?
-8x8 vs. 12x12? What is the difference in hardware if any?
-MSII, plug in board, what does it mean in terms of features?
-If I buy a ready built MS with a flyback board, what do I need to make it control spark? Dizzy system now, nothing fancy.
Is it possible to answer these questions without saying "all the info is available on (insert link to insanely large forum here)" or the MSII is using (model number of processor) and thats is the difference.
I wanna know what it means to me, not what the electrons will experience.
I know that I'm asking a lot in this post but if you guys want more people to start using megasquirt you should realize that we dummys want simple info and doesn't care about the individual specs of the transistors, just what it means to us as users.
Thanks guys!
