The time has come to move on i guess, My first alfa needs to leave the stable.
The car is being sold to make room for the new GTV6 track car. Im not 100% done the 3.0 conversion, but i figured if i could sell it now and give someone a good deal it also frees up the space for me. Win - Win. I am still continueing work on it, so if no one wants a 90% done project then it will become a 100% dont car in a month or so.
The car is a 1981 GTV6 with 75K miles. She has electronics from a '84 GTV6, a BMW ECU, bigger flow BMW injectors, and big 3" BMW AFM. The car has Greg Gordon Vac hoses (Black) and a Greg Gordon air intake. It also has the Greg Gordon idle control valve (NLA!) that replaces the thermo idle control valve. The 2.5 is still in the car, but everything else is out and all connectors are labled and ready to be plugged into new engine so it wont run now.
The interior was has the much better seats from an '84 GTV6, then totally redone in red and white, a 140 MPH speedo, and short shift lever. The paint could be redone, but it isnt terrible by any means. No exterior rust on the car, the floor pan could use some work. The tire and battery box were cut out and repaired with 3 ply fiberglass. The '86 GTV6 wineglass wheels look good on it.
The 3.0 is from a '92 164L, it has everything that it needs to go into the car except the bellhousing and flywheel spacer. The engine has 60K miles and everything looks good on the inside. I changed dizzy drive gear, dizzy, oil pump, oil pan, crank pully, water pump, and probably some other stuff.
The car can also include a new tranny with 500 miles on it, NO 2nd gear crunch. The tranny can also be sold seperate.
As far as price just bombard me with offers. Im really dont have set number right now, it also depends on what kind of a home she is going to . Im going to continue on with the conversion if i dont get a buyer. Once is running and all the bugs are out it goes on Evilbay
**** more pics and info at: http://www.alfabb.com/bb/forums/showthread.php?t=14886 ****
Now the pics!!
FS: 1981 GTV6 w/3.0
- 1d_1.jpg (26.87 KiB) Viewed 4553 times
- 6f_1.jpg (33.84 KiB) Viewed 4553 times
- 52_1.jpg (25.67 KiB) Viewed 4553 times
- DSC00008_1.JPG (61.1 KiB) Viewed 4552 times
- DSC00009_1.JPG (60.72 KiB) Viewed 4553 times
Jacob Ricciotti
'81 GTV6 3.0
'81 GTV6 Track car
'91 164S daily driver
'81 GTV6 3.0
'81 GTV6 Track car
