As a new GoTech user I want to check with others, but how accurate are the reading from the GoTech?
The reason I ask is that for example the coolant temp on the GoTech shows around 104-117 C, while the engine temp sensor shows 80 C. They are both reading from the same place on the thermostat housing so they should have similar readings. A difference of at least 20 C is pretty big.
Also the AFR reading off the O2 sensor does not match. The GoTech screen wouls show 740-760 mv, while reading straight off the O2 shows 680-690 mv.
Is there some way to calibrate this settings or which is right?
GoTech reading accuracy
ANDREWG
1982 GTV6 ITS #63
1988 Milano Verde - Project car
1988 Milano Verde IMSA IS - now SCCA ITE
1991 164S
www.garciaalfaracing.com
1982 GTV6 ITS #63
1991 164S
Although Alfa instruments are sometimes not accurate, I would actually trust the Alfa instrument in this case. You can check by running it on the freeway and watch the temp readings. Assuming your thermostat is working you should be at the optimal temp, 80C, or whatever it is, and can see which device is correct. You can also watch which device provides the most accuarte temps for radiator fan on and off - forgot them off the top of my head. Anyway, my reason for trusting the Alfa instrument is that I can imagine there could be a calibration issue between the GoTech ECU and whatever temp sensor Alfa is using. Of course, your engine temp sensor could be bad, but given that Sam, and I as well, have similar observations then...
Keep in mind that if you do find a calibration and proceed to calibrate it, then your map effectively will change, as a given operation point will now receive a different water temp correction since the ECU is observing a corrected (different) temp. So, all such calibration issues should probably be sorted prior to expensive dyno time, or forever live with an inaccurate temp reading, and simply do the tuning based on that.
Or, you purchase a water temp from GoTech. I believe they sell some. That should work. If you are lucky even the thread on the housing matches...
What type of sensors does GoTech supply with its units? I assume they much use standard sensors that currently exist from some car maker.
ANDREWG
1982 GTV6 ITS #63
1991 164S
1982 GTV6 ITS #63
1991 164S
- junglejustice
Yep - I have purchased several - and taken a few of the A/F units back to South Africa for Barry, Dawie, Stewey et al... We are going to permanently install one of the Innovate digital meters in the 156 GTA race car and I think that this is the route that Barry picked as well...
Re: GoTech reading accuracy
I don't agree with this. The end device - the analog gauge may be where yr inaccuracy is. It is not a precision instrument by any means. Also if it's ground path is poor, you could have a lower reading.aggarcia wrote:They are both reading from the same place on the thermostat housing so they should have similar readings.
Usually in closed loop temp control systems, you have to specify the type of reading device, eg: a k-type thermocouple. Does the GT software give you the option to spec the reading device? Or are you using a GT temp sensor?
