Giulietta24vTT
Gearbox oil cooler+pump
Post by Giulietta24vTT »
Did anyone fit a gearbox cooler with a circulation electric oil pump similar to the ones fitted originally on the SZ\RZ ???
According to the SZ technical disc it seems that the pipes are connected to the gearbox from top and bottom and the cooler is fitted on the right center bottom of the vehicle on the upper pit.
We all know how hot it gets there especially with the rear TX brakes on the rear end and the exhaut pssing close....
What kind of electric pump will enable circulation of oil?
Can I fit an electric steering oil pump(like the one that comes on the citroen VTS) ?
Chen S
ex Giulietta 24V Glenwood TT.
ar4me
Post by ar4me »
You can use a Mocal differential cooler pump - $180 at www.racerpartswholesale.com. Not cheap, but probably good.
Giulietta24vTT
Thanks Jes!
I actually bought a Mocal Oil cooler from a local dealer recently,
very cheap and top quality.
Should I locate the pump's inlet lower than the gearbox?
Chen S
GTV6GPTT
Post by GTV6GPTT »
do you think you can post the pictures of the sz tech pics.
thanks
GTV6GPTT
Post by GTV6GPTT »
bump
enzo
Post by enzo »
here is one
