Can someone plese tell me where the wire going from the NOX sensor on the thermostat housing goes?
I'm just wodering becasue instead of disconnecting mine someone cut the wire going to it. and i can not find the wire. So i'm thinking that pehaps the wire is hitting ground and giving me some problems?
thanks
I think that what you are referring to is the "cold start retard" sensor,which should be disconnected per Alfa tech bull.(see images) The L-Jet system does not have a knock sensor if that is what you meant.
- CSR1.jpg (54.45 KiB) Viewed 3795 times
- CSR2.jpg (47.12 KiB) Viewed 3794 times
- csr3.jpg (52.75 KiB) Viewed 3794 times
